Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2017
    Location
    iran-tehran
    Posts
    4
    Post BEGINNER SERIES - CHOOSING A PLANE for persian
    hello to all
    i have devided this article:
    https://www.flitetest.com/articles/b...oosing-a-plane
    to 3 partitoin and now i translate it to persian in order that persian use your good sites not....
    http://bibbib.ir/index.php?route=blo...e&article_id=1
    http://bibbib.ir/index.php?route=blo...e&article_id=2
    http://bibbib.ir/index.php?route=blo...e&article_id=3
    for persian:
    سلام
    چه مدلی بخریم؟
    چه رادیوکنترلی بخریم؟
    سرعت این هواپیما چقدره؟
    برای پاسخ به این سوال ها
    روی سه لینک پشت سر هم کلیک کنید
  2. #2
    Site Moderator JimCR120's Avatar
    Join Date
    Oct 2011
    Location
    Central Maine
    Posts
    2,335
    Hello bibbib. Translation is not a small task even when you are dealing with well known languages.
    I am interested to know what experience you have in the hobby and what interests you might have.
    Welcome to the forum.
    —Jim
    Truths in life:
    1) Everything that happens happens for a reason. Luck does not exist.
    2) In this existence we are part of the problem or part of the solution. The choice is ours.
    3) We aren't defined by our circumstances but by our reactions to them. Crisis reveals character.
  3. #3
    Join Date
    Jul 2017
    Location
    iran-tehran
    Posts
    4
    I tried several times to make the flitetest models, but each time I encountered a problem, I tried to cut it with a cuter but it wasn't exact work now I'm testing it with a laser cnc and I did it on the way.
  4. #4
    Kite Eating Tree Trimmer cranialrectosis's Avatar
    Join Date
    Jul 2013
    Location
    Colorado Springs
    Posts
    5,164
    Welcome to the FT Forums, bibbib!
    Sorry you had trouble cutting some of the plans. What type of foam board are you using?
    Hope to see some photos of your planes with instructions in Persian soon!
    Freiheit schöner götterfunken tochter aus elysium!
  5. #5
    Join Date
    Jul 2017
    Location
    iran-tehran
    Posts
    4
    i dont have some information about foam board but this pic say you..
    Click image for larger version.
  6. #6
    looks like a double layered foam board. very interesting. if that is the case, then your airplanes are gonna be 2 x as heavy, that might explain some of your struggles. i would invest in a digital scale to weigh your planes, and coughing up $10 to have full access to this website... eCalc. it will tell you if you are heading in the right direction as far as weight, motor, prop, and battery.
    what problems were you having with cutting you foam board like normal with a razor blade?
    it looks like the laser you are trying to use is way too hot and just melting stuff. there is an FT article about a CNC needle cutter that you might look into. uses a brushless motor and sewing needle to cut foam board. no heat required.
    welcome to the club!
    lates,
    jason
  7. #7
    Join Date
    Jul 2013
    Location
    Colorado Springs
    Posts
    5,164
    +1 MrJdStewart
    That foam looks double thick and using it will add complexity.
  8. #8
    Join Date
    Jul 2017
    Location
    iran-tehran
    Posts
    4
    so I will use one layer foam
    Thanks guys
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
