Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
  1. #21
    lawrenceyy's Avatar
    Join Date
    Jul 2017
    Location
    Beaverton, OR
    Posts
    19
    Quote Originally Posted by SlingShot View Post
    That sounds nose heavy...
    It probably is a little nose heavy. The motor and esc I have now are heavier than before, and they sit far forward of the ideal CG. Maybe my new larger capacity lipos will counter-balance this.
    INSTAGRAM: @lawrenceyyun
    RHINO 3D + GRASSHOPPER 3D + FUSION 360
    LASER CUTTING + CNC ROUTING + 3D PRINTING
    ILLUSTRATOR + PHOTOSHOP + INDESIGN
  2. #22
    lawrenceyy's Avatar
    Join Date
    Jul 2017
    Location
    Beaverton, OR
    Posts
    19
    I thought I'd give everyone an update. I flew the bugatti on the 800mAh 3s battery today, and it flew so much faster. I'm very happy with how this plane turned out: very fast, very nimble, very responsive.
    One thing that caught me off guard the plane rolling right. I had to trim my ailerons to the left 50 clicks before it leveled off. The plane does not have any significant balance issues (weight-wise) about the roll axis. I've always had to put some left trim, but with the new motor/battery combo, I definitely needed to add more. My motor spins the typical direction- I wonder what is causing this.
  3. #23
    lawrenceyy's Avatar
    Join Date
    Jul 2017
    Location
    Beaverton, OR
    Posts
    19
    It occurred to me that most people may not have access to a laser cutter, so I repackaged my plans to be printable on 8.5"x11" paper. I've added the file to the original post.
  4. #24
    Roll to right
    Lawrence,cool build,do you have any right thrust built in? If so you may want to zero it.
    how bout making a 700mm kit for us ......cnc foam cut?
    tnx
  5. #25
    lawrenceyy's Avatar
    Join Date
    Jul 2017
    Location
    Beaverton, OR
    Posts
    19
    Quote Originally Posted by charlesdietz@hotmail.com View Post
    tnx
    My motor is mounted straight on. I never give my planes any thrust angle.
    What do you mean by a kit? The plans are posted. I've never cut foam board on the CNC (I have milled wings and fuselages). Laser is faster, although the foam shrinks at the lasered edges.
  6. #26
    700mm Bug
    Quote Originally Posted by lawrenceyy View Post
    Sorry,I meant to say Laser cut....Yeah it will melt a bit on the edges...The FT kits are all slightly shrunk at the edges according to the pics I've seen... ...I usually rely on the trusty sharp blade in my utility/xacto knives
    Well time to print your plans and get cutting..
    Cheers
  7. #27
    lawrenceyy's Avatar
    Join Date
    Jul 2017
    Location
    Beaverton, OR
    Posts
    19
    Cheers
    If you live in the Portland area, you'd be in luck. I fly with a group of guys and often help them laser cut flitetest kits out of foam board.
  8. #28
    Smile Cutting kit
    Well I'm about as far away as you can get in the US(except Alaska)....Florida..but UPS delivers ...
    Cheers
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
