Quote Originally Posted by Bricks View Post
The unpumped carbs the tank level placement is critical and as short of a run as possible. Other things to check the fuel nipples have a blue gasket under them which are junk easiest is to use a little locktite on the threads versus making a new gasket, when installing the venture make sure the O ring is good and apply down pressure on the venture as you tighten up the screw. These 2 things have cured many mid rpm problems and double check all fuel lines for tiny cracks had that one happen to me took 2 weeks before I found my problem could not even see the crack and it was new fuel line. Worse comes to worse going to a pumped carb cures about all problems with these small gas engine.
Thanks Alot for the Tip!!!!
