Results 1 to 9 of 9
  1. #1
    Jetcrafter_2000's Avatar
    Join Date
    Aug 2017
    Location
    Germany, Stuttgart
    Posts
    151
    Question Hotwire template
    Hi guys!
    I already tested out several materials (wood, cardboard and metal) but every time i got stuck at a notches or scratches.
    Which material do you use for hotwire templates?
    I could use metal sheets but that would be pretty expensive in the end and i donīt want to spend a whole week in building templates.
    Every help is welcome!
    Jetcrafter2000
  2. #2
    jtrops's Avatar
    Join Date
    Oct 2016
    Location
    Longmont, CO
    Posts
    188
    I haven't used a hot wire for making plane parts. I think the materials you have used should be fine. You may need to spend a little more time refining the templates so that they don't have things that will catch the wire. Maybe a hardboard/Masonite sort of material would work since it is a stabilized product without grain, but easy to work like wood.
    I would cut the raw template out leaving plenty of material outside the line, and then sand it down to the line. As you get to the line switch to finer sandpaper until you are polishing the edge. This should eliminate the hang ups. I don't know if there is a wax that would resist the temperature of the wire, but lubricating the templates may help as well.
  3. #3
    Bounty Hunter thenated0g's Avatar
    Join Date
    Jun 2014
    Location
    Lakeport, ca
    Posts
    805
    I have had the most successful using aluminum flashing. Cut with scissors and sand it smooth. Very cheap.
  4. #4
    Join Date
    Aug 2017
    Location
    Germany, Stuttgart
    Posts
    151
    Thank you!
    Iīll try out your techniques today.
  5. #5
  6. #6
  7. #7
    Cardboard Boy Fluburtur's Avatar
    Join Date
    Jul 2016
    Location
    France
    Posts
    471
    I make my templates in carboard with aluminium tape.
    Click image for larger version.
    I sometimes put a bit of cyano glue at the trailing edge to make it a bit stronger.
  8. #8
    Skill Collector rockyboy's Avatar
    Join Date
    May 2015
    Location
    Alexandria, VA USA
    Posts
    3,653
    Another user of cardboard or foam board forms with aluminum tape on the edges here.
    I want YOU to join us in the 2018 Flite Test Forum WWII Design/Build Challenge!
    My hanger listing, build threads, conversion projects, and Taranis radio mods are Over Here....
  9. #9
    Join Date
    Jun 2014
    Location
    Lakeport, ca
    Posts
    805
    On my f-100 i decided to use thin plywood. I had a similar problem as above where it would catch on the wood. It was actually burning itself into the wooden templates and catching and burning holes in the foam. Next time i try wood i will try your super glue idea on the edges, but i think next time i try something other than aluminum flashing i will try melamine covered wood and see how that deals with the heat.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
