Results 1 to 2 of 2
  1. #1
    Connecting motor to ESC?
    This is a Flight Test A power pack. What motor leads connect to the ESC, or how do identify what motor leads connect to which ESC lead??Click image for larger version.
  2. #2
    Construire Voler S'écraser Répéter French's Avatar
    Join Date
    Mar 2016
    Location
    Tallahassee, FL
    Posts
    1,124
    Connect up the three as show. Plug in a bound receiver to the ESC’s servo plug. Turn on your radio. Plug in a battery to the esc battery plug. Give it a little throttle and test which way the motor is spinning. If it’s spinning the wrong direction, unplug the battery and switch any two of the motor lead wires.
    Check these out:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
