Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 10 of 111
    Administrator ftadmin's Avatar
    750
    Tricopter - Scratch Build
    Check out the main Article post HERE
Name:	Tricopter Build - 2.jpg
    Parts used in this build:
    1 x Tricopter frame
    1 x M3*20 screws + locknuts
    1 x KK2 flight controller
    1 x Male to male servo connectors
    1 x 3 X 3.5mm bullet ESC Power Breakout Cable
    3 x DT750 750kV Motors
    3 x Hobbyking F20A Speed Controllers
    1 x4s Turnigy 3000mAh LiPo
    1 x BMS-385DMAX Digital Servo (Metal Gear)
    1 x Gemfan 9x4.7
    1 x Front wheel steering mounts
    1 x Male to male servo cables
    1 x M3x30 Hex screws (if building the camera tray)
    1 x M4 lock nuts (for the DT750's)
    1 x Distribution power adapter
    1 x Battery strap
    1 x Servo extension
    1 x 3.5 bullet connectors
    (Items without a link I've bought at local shops)
    4 mm carbon fiber rod
    40+ of 2.5mm zip-ties
    1/16th plywood (if building the camera tray)
    Blue locktite
    CA glue
    12mm (1/2 in.) Boom - (Poplar Square Dowel)
    Boom Lengths:
    Front: 35cm
    Back: 37cm
    Camera Tray Plans:
    Tricopter Frame PDF
    Tricopter Camera mount PDF
Name:	Tricopter Build - 3.jpg
ID:	9333Click image for larger version.
Name:	Tricopter Build - 4.jpg
ID:	9332Click image for larger version.
Name:	Tricopter Build - 12.jpg
ID:	9324Click image for larger version.
Name:	Tricopter Build - 5.jpg
ID:	9331Click image for larger version.
Name:	Tricopter Build - 6.jpg
ID:	9330Click image for larger version.
Name:	Tricopter Build - 7.jpg
ID:	9329Click image for larger version.
Name:	Tricopter Build - 9.jpg
ID:	9327Click image for larger version.
Name:	Tricopter Build - 10.jpg
ID:	9326Click image for larger version.
Name:	Tricopter Build - 8.jpg
ID:	9328Click image for larger version.
Name:	Tricopter Build - 11.jpg
ID:	9325Click image for larger version.
Name:	Tricopter - option.jpg
ID:	9306Click image for larger version.
Name:	Tricopter Build - 13.jpg
ID:	9323Click image for larger version.
Name:	Tricopter Build - 24.jpg
ID:	9313Click image for larger version.
Name:	Tricopter Build - 22.jpg
ID:	9315Click image for larger version.
Name:	Tricopter Build - 15.jpg
ID:	9321Click image for larger version.
Name:	Tricopter Build - 16.jpg
ID:	9320Click image for larger version.
Name:	Tricopter Build - 14.jpg
ID:	9322Click image for larger version.
Name:	Tricopter Build - 17.jpg
ID:	9319Click image for larger version.
Name:	Tricopter Build - 18.jpg
ID:	9318Click image for larger version.
Name:	Tricopter Build - 23.jpg
ID:	9314Click image for larger version.
Name:	Tricopter Build - 21.jpg
ID:	9316Click image for larger version.
Name:	Tricopter Build - 19.jpg
ID:	9317Click image for larger version.
Name:	Tricopter Build - 32.jpg
ID:	9307Click image for larger version.
Name:	Tricopter Build - 27.jpg
ID:	9310Click image for larger version.
Name:	Tricopter Build - 25.jpg
ID:	9312Click image for larger version.
Name:	Tricopter Build - 26.jpg
ID:	9311Click image for larger version.
Name:	Tricopter Build - 1.jpg
ID:	9335Click image for larger version.
Name:	Tricopter Build - 28.jpg
    Senior Member Bolvon72's Avatar
    Virginia
    450
    Great to see David doing a build thread, I already have mine in the air, but there is still so much to learn about this tri.
    lumpy member zev's Avatar
    Jan 2013
    Natick MA
    374
    thank you thank you thank you. you guys are the awesomest, most devoted, incredible guys out there.
    this in my next tricopter!
    "reading is for stupid"
    Apr 2013
    Hello, thank you for this great tutorial!
    I was waiting for something like this for ages so i can finally start collecting recources and make my own tricopter
    As a beginning flyer what would be a good transmitter/ receiver in combination with this build, maybe something i can expand later to use to do some fpv with my gopro?
    Thank you for your time
    Senior Member RoyBro's Avatar
    Apr 2013
    Big Sky Country, Montana
    1,179
    Can you recommend an alternate source for the steering mounts? Hobby King seems to have been back-ordered for some time now.
    Or if anyone out there has built theirs and have left over parts, maybe they'd be willing to share or sell.
    Australia
    54
    Post
    you cant go past the Turnigy 9X
    there is some other designes out there;
    http://iterativecode.com/blog/2012/0...sm-revision-2/
    or you can watch more youtube videos and waight for them to come in stock
    Misfit Multirotor Monkey Cyberdactyl's Avatar
    Sep 2012
    Raleigh, NC
    2,772
    Quote Originally Posted by RoyBro View Post
    HERE is an RCGROUPS thread slam full of all sorts of yaw designs
    Singularity: A future period during which the pace of technological change will be so rapid, its impact so deep, that human life will be irreversibly transformed. Although neither utopian or dystopian, this epoch will transform the concepts we rely on to give meaning to our lives, from our business models to the cycle of human life, including death itself.
    ~Kurzweil
    Stuck in Sunny FL FlyingMonkey's Avatar
    Ponce de Leon, Florida, United States
    4,007
    http://shop.flitetest.com/multirotor...s-tilt-13-370/
    Apr 2013
    13
    Hi David. After seeing this episode on Flitetest, I've decided to take the plunge into RC. I want to build a tricopter like yours for my first RC model. I have a couple of questions. First, if I get a Turnigy 9X or 9XR, what RX and TX do you recommend? Do you think a tricopter is a good first heli? And lastly, if I decide to get the Hobby King X900 tricopter frame to use as a starter kit, would I use the same electronics you've listed here or would you recommend any changes? Oh yeah...and what does HV mean?
    Apr 2013
    1,179
    I was just notified that Hobby King has them back in stock, although not at the USA Warehouse. So I placed my order right away.
    http://www.hobbyking.com/hobbyking/s...idProduct=8432
