Results 1 to 10 of 15
Thread: Skywalker X8
    Administrator ftadmin's Avatar
    750
    Skywalker X8
Name:	x8 - 21.jpg
ID:	9457Click image for larger version.
Name:	x8 - 23.jpg
ID:	9456Click image for larger version.
Name:	x8 - 6.jpg
ID:	9474Click image for larger version.
Name:	x8 - 7.jpg
ID:	9473Click image for larger version.
Name:	x8 - 10.jpg
ID:	9469Click image for larger version.
Name:	x8 - 9.jpg
ID:	9470Click image for larger version.
Name:	x8 - 2.jpg
ID:	9471Click image for larger version.
Name:	x8 - 20.jpg
ID:	9458Click image for larger version.
Name:	x8 - 8.jpg
ID:	9472Click image for larger version.
Name:	x8 - 11.jpg
ID:	9468Click image for larger version.
Name:	x8 - 5.jpg
ID:	9475Click image for larger version.
Name:	x8 - 4.jpg
ID:	9476Click image for larger version.
Name:	x8 - 3.jpg
ID:	9477Click image for larger version.
Name:	x8 - 12.jpg
ID:	9467Click image for larger version.
Name:	x8 - 24.jpg
ID:	9478Click image for larger version.
Name:	x8 - 1.jpg
ID:	9459Click image for larger version.
Name:	x8 - 19.jpg
ID:	9460Click image for larger version.
Name:	x8 - 17.jpg
ID:	9461Click image for larger version.
Name:	x8 - 16.jpg
ID:	9463Click image for larger version.
Name:	x8 - 15.jpg
ID:	9464Click image for larger version.
Name:	x8 - 18.jpg
ID:	9462Click image for larger version.
Name:	x8 - 14.jpg
ID:	9465Click image for larger version.
Name:	x8 - 13.jpg
    Moderator earthsciteach's Avatar
    6,731
    My scratch built fpv wing can fly upside down. Just sayin'...
    I'm quite surprised to hear that the fit of the components was so poor. Not sure what to make of the flutter. I haven't pushed my fpv wing that hard, but am pretty confident in the rigidity of the xps foam covered with the thin fiberglass.
    I designed mine with time aloft in mind. I wanted to come up with something that could carry multiple cameras and be airborne long enough on a reasonably sized battery (3300 mah, 3 cell) so that the battery weight didn't dominate the payload.
    From the review, it seems like the X-8 does a nice job of doing just that. Plus, I really do like the looks of it. My fpv wing V2 is going to have a longer nose, more similar to the X-8 and be tipped with a clear dome to keep the camera totally enclosed while allowing movement. I think that will be a big improvement over the X-8.
    I would REALLY like to see a build video on the 360 degree angle camera mount David built!
    Self-appointed Flite Test Forum Ambassador
    Official Winner of the Flite Test Forum STOL Build Contest
    I'm a care bear...Really? CrashRecovery's Avatar
    Jan 2013
    Elkton MD
    2,279
    Ditto on the camera setup. Anyone notice the resemblance to the b-2 stealth flying wing? The body sure looks like it!
    That's not a drone. That's an MCI - a Multirotor Controlled by an Idiot.
    Great review. For those of us planning to run this plane with the APM 2.5, can you link to any custom files or settings you used?
    After you pointed out the ridiculousness of that front lower camera mount, I'm considering removing that bulge entirely (hot wire?) Any thoughts?
    Ohio
    4
    Nice review .
    I see your using ezUHF and 1280Mhz FPV video. Which one of you has the Ham ticket ? Because you can't use that equipment unless you have a Ham ticket from USA. or have a Ham ticket for an other country and have notified the FCC that you plain to use it while your here in the USA.
    Don't forget if one of you do have a Ham ticket They have to be there when your using that equipment.
    If you don't have one there easy to get. You'll need a Tech class at the minimum .
    Keep up the good work !
    SETUP of ARDUPILOT 2.5
    Hi guys, excellent Review. I do have the same plane and planning to equip it with the ARDU as well. Do you have any tips on the Setup for the Ardu or is it just straight forward? Thanks a lot
    Apr 2013
    3
    Really enjoyed the review guys and watched it right thru. Yep the X-8 does have a few annoying fitting issues. The raised area at the trailing edge was actually an intentional addition of reflex in the wing, but I would think it looks better to tape it up (I used location pins) and just use the elevons for reflex. One of the main advantages of the X-8 is it's huge lifting capacity. Even for FPV work, you can use some of that capacity for wing strengthening to make the model safer and more versatile. I built one purely as a fun aerobatic and ridge soaring ship - a couple of vids here:
    https://vimeo.com/54651365
    https://vimeo.com/62681987
    Far, far away
    507
    David, could you please flesh out the details on the 433 LRS? Especially the antennas at both the transmitter and receiver end. The transmitter antenna looks like a full wave, but what's up with the dual receiver antennas? Half-waves? Why the angle? I guess you'd have to match up the impedance as usual?
    Apr 2013
    0
    Question Parts List?
    Hey David, can you make a list of all the parts inside this masterpiece? Im hoping to make an exact replication of the X8 that you guys use. and what was that ground antenna?
    0
    Quote Originally Posted by Charles Beener View Post
    Nice review .
    I'm sure that these guys have done the right thing. If you have watched a number of their episodes you would have noticed they act responsibly.
    Thanks for pointing out the obvious though.
