Page 147 of 147 FirstFirst ... 47 97 137 145 146 147
Results 1,461 to 1,465 of 1465
  1. #1461
    Still Learning
    Join Date
    Feb 2016
    Location
    Maryland, US
    Posts
    535
    Quote Originally Posted by Spitfire76 View Post
    I just received the FT Spitfire as I could not wait for the revised version. When I met Josh at FliteFest west he said it would be several months before v2 is available. The order included a power pack C and battery but I noticed that the motor, an Emax Grand Turbo GT2215/09, takes a 3S battery but the battery that I received is 4S, Hyperion 4S, 2100,mAh
    I thought the GT2215/09 is not rated for 4S - only 3S?
    Mike
  2. #1462
    Quote Originally Posted by mikeporterinmd View Post
    Mike
    The motor is rated at 3S but when you order the optional battery on the FT store its a 4S.
  3. #1463
    Still Learning
    Join Date
    Feb 2016
    Location
    Maryland, US
    Posts
    535
    Yeah.. I didn't read far enough back in the thread to catch your point. Someone might burn up a motor if they don't notice?
    Mike
  4. #1464
    I have motor Scorpion SII-3014-1220KV 129gr. Not too heavy? With 4s2p lio-ion 6000 about 400gr and prop 7x6. I want a high-speed birdie, but also that remained maneuverable. as you think with such setup will fly normally?
    I read on a MPX Dogfighter put the motor weight 140gr, and it wingspan only 88cm.
  5. #1465
    Join Date
    Oct 2017
    Location
    Goshen, IN
    Posts
    43
    I haven't built the spit, but I'd imagine it would work fine. Your battery may bit a bit heavy but I don't see why you would have any problems. Certainly not as big of problems as Bixler had...
    https://youtu.be/Fv27vvyi-gw?t=116
Posting Permissions
  • You may not post replies
  • You may not edit your posts
