Results 1 to 5 of 5
    May 2013
    4
    FPV System - 900Mhz Hobbyking~ Wiring Fault
    Hello,
    I recently purchased the hobbyking 900Mhz FPV Kit.
    I noticed the wiring that goes to the camera is backward,
    Mine is :
    VIDEO NEGATIVE POSITIVE
    its supposed to be
    POSITIVE NEGATIVE VIDEO
    how do I re-wire the wires to be the right way?
    thanks in advance,
    -axel.
    Stuck in Sunny FL FlyingMonkey's Avatar
    Ponce de Leon, Florida, United States
    4,010
    Can you post a picture of what you're describing?
    Liemavick's Avatar
    Mar 2013
    South Florida
    483
    I believe this might help...
    http://www.youtube.com/watch?v=EgGMtLzmDYI
    Brian
    What have I gotten myself into?
    May 2013
    4
    Quote Originally Posted by Liemavick View Post
    Brian
    Yes, what im wondering though, is how i should flip the wiring.
    Also,
    I can upload a pic tommorow for sure.
    Jun 2013
    Calcutta, India
    60
    Have you fixed it? Mine came with the same problem. On the white connector, you'll see a tiny plastic flap/tab just behind where you can see the metal connector inside. Take a pin some small sharp object, lift the plastic tab and pull the wire out. Then just push it back in. Hope I've been able to explain it.
