Results 1 to 5 of 5
    Old Fogey wing support / reinforcement
    Hi Guys,
    I folded the wings on my dads Fogey today trying to do a loop (yes I know it is not designed for that). What is the best way to reinforce the wing to make sure it doesn't happen again? I quickly taped a BBQ skewer on the under side in the bend of the wing to act as a spar but I want to build a new wing and make it stronger from the get go. Any ideas and or alternate wing designs?
    Thanks
    BTW, this is the video of me folding the wings
    Dedicated foam bender xuzme720's Avatar
    Houston, Texas
    4,903
    Boxing the center section would make it stronger, but you would lose the undercamber there. It might be worth a shot though to build a test wing to see if it works.
    Yes, I DO call that a landing! It's on the ground, isn't it?!
    http://www.youtube.com/user/xuzme720/videos
    It's pronounced "excuse me 720" or call me Gary, my mom always did.
    "If you are flammable and have legs, you are never blocking a fire exit!" M. Hedberg
    creator of virtual planes rcspaceflight's Avatar
    Wisconsin USA
    3,134
    Quote Originally Posted by xuzme720 View Post
    I built a plane with the same "cracked" wing airfoil as the Old Fogey, except my wings where 60" long with a 10" cord. I made the center part of the wing (30" long) with a flat bottom and then had the wing tips undercambered. My plane also had dihedral on the wing tips. Basically, I know from experience that making the center part of the wing flat bottom, just add a piece of foam board to the bottom, strengthens the wings enough to do loops. Although technically the loop I tried to do with my plane was unsuccessful, but that's because I ran out of room and nose dived into the ground. But the wings out lasted the plane.
    36 add on planes for RC Desk Pilot (including a lot of Flite Test models)
    ::I am officially taking a break from this hobby. And I will not be checking this forum very often.::
    Thanks for the tip. I think that's what I will do. I will cut the fuselage straight and then make the bottom of the wing flat with a foam spar for reinforcement. That should also strengthen the leading edge as well which is important as my dad is drawn to trees for some reason. I'll let you know how it loops
    Houston, Texas
    4,903
    Quote Originally Posted by MEGAjig View Post
    I don't think it's just your dad. I've had trees jump out in front of me more than once. I think they are jealous of the planes mobility and wait in ambush to take them out...
