Results 1 to 10 of 13
    Crazy flyer/crasher :D ananas1301's Avatar
    Germany
    1,480
    Futaba FASST vs. Spektrum DSM2/X
    Hey guys,
    my modelsavings have increased a bit and the DX6i wont have enough saving for it in a year or so and I wanted to just get some more knowledge about those two systems in comparison to each other.
    As far as I know Spektrum is good but Futaba is better.
    Pros for Spektrum:
    - Awesome design
    - cheap orange rx clones are available
    Cons for Spektrum:
    - Range (at least I have a more limited range than most of you do)
    Pros for Futaba:
    - Okay desing
    - much safer than Spektrum (from what I heared so far)
    Cons for Futaba:
    - expensive, I dont know about any cheap clones for the FASST system yet and I dont really know the system.
    Just wanted to hear about what you heared and what you use for which purposes.
    Of course Ill never stick a Spektrum receiver into a jet turbine and I am never going to get one (well I think ) but what do you think about this?
    BTW does anyone know which radio David Windestal uses? I think it is Futaba.
    Oh yeah and one further question:
    I want to get a radio soon but that should last me for a very long while because I really cant be asked to keep looking into TX systems. So one tx forever! (at least for a few years)
    And a possibility would also be to get a DSM2/X module for the TX so I can still use both systems
    Senior Member JoeyG's Avatar
    Nottingham, UK
    132
    I have a limited understanding but the way I see it, it comes down to what sort of flying you want to do.. I was looking at a Futaba yet went with a Spektrum. I choose the Spektrum for its features and price, the only short comings I see with the Radio I have is range. Plenty for park flying which is all I'm doing but I fear it would fall short for FPV.
    J.
    More combat please... jetpackninja's Avatar
    Gravity bound to the 3rd planet (Lehi, Utah)
    1,609
    I think there are orange RX FASST compatible receivers at HobbyKing?
    I don't personally know anybody that uses them.
    Me? DX6i and OrangeRX 6 all the way.
    I think, therefore I crash
    Old age member pgerts's Avatar
    Fjlkinge Scania Sweden
    1,552
    I do not think that the technology is the problem. I suppose that you can get sufficient range with the more expensive receivers to any system and that you have to be careful with cheaper versions and clones if the system is DSM or FASST. Its probably OK with Orange FASST or DSM if you are flying parkflyers AND you are checking the range. Don’t trust that every receiver is perfect because another similar is fine.
    Choosing between Spektrum and Futaba is probably like choosing between BMW and Mercedes. You have to get the feeling and go for the system that fits you. Was the World champion in F1C using DSM?
    If you are going for FPV then you will probably go for something else than 2,4 if you want range.
    Senior flyer - every gram counts!
    Big Foig Paintball_kidz's Avatar
    Vancouver, British Columbia
    17
    I recently switched from Spektrum to Futaba fasst, my reasons are...
    Better range
    More reliable
    Faster response time
    Cheaper full range receivers
    If you look at most the imac & freestyle pilots, most of them are using Futaba fasst but also using JR DSM(2)(X).
    Dadde use to use futaba but he experienced Gyro problems compatibility with the futaba receiver, hes now using Hitec Aurora 9.
    Germany
    1,480
    Quote Originally Posted by pgerts View Post
    Yeah thats true but I wanted to stay with 2,4Ghz for the RC connection because for my purposes Ill just do FPV in a closer range but still the current range of the DX6i I use wouldnt be enough.
    I just had a look at what David Windestal uses. If you go his videos you can see which tx and rx he used. For the first couple of videos he had a Futaba 7C but then for the rest up to the newer ones he has used and is still using (so I assume) is a Hitec Aurora 9. I had a look at it and it actually looks quite nice. At least it looks nicer then most of the Futaba txs. It also has a lot of features but therefore has its unbelievable price of about 380€ (I think). But I think there arent any clones out of the AFHSS (that is the system used with Hitec tx and rxs)
    I might have to look for some module to be able to use both DSM (for my current receiver and just to be able to get some cheap receivers from HK for smaller range planes) and then just one or two of the good ones for the range I need in FPV.
    Does anyone have any other suggestions of what might be good in my case here to choose? The only thing I need to decide now is which of the Futaba I would choose. And then if I should go for the Futaba or the Hitec Txs.
    I just want to build up everything correctly right from the start because if Ill buy a DX7 and then another one for better range and all that I will have different radios to carry around or I will have to keep buying more and more stuff and in total it would be cheaper to have one good one from the beginning! (At least that is the way I am thinking)
    Ill look into the Txs over time now and tell whats going on.
    1,609
    The Aurora 9 is likely worth consideration. I have friends who use them and they never complain.
    Hitec also has excellent customer service.
    17
    hitec aurora my friend tested out to 1.1km and got locked out.
    Germany
    1,480
    Quote Originally Posted by Paintball_kidz View Post
    what do you mean with got locked out?
    sorry for my bad english understanding but I really wanna know that
    Stuck in Sunny FL FlyingMonkey's Avatar
    Ponce de Leon, Florida, United States
    4,010
    Lock out is a term used to explain a lack of communication between the transmitter and the receiver.
