Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Airfoils
    Administrator flitetest's Avatar
    719
    Airfoils
    In this episode of Flite Test Josh and Josh teach us how to build planes out of foil? Well maybe not, but they do explain air foils pretty well. Watch this to learn more.
    Crazy flyer/crasher :D ananas1301's Avatar
    Germany
    1,480
    Awesone episde!!
    It was well worth the wait!
    Love that start with Josh Sīs aluminum foil
    ALSO cant believe what I saw there at the end!
    The next episode it just gonna be awesome to the power of 20 times avater!!
    Another great episode guys! I have really learned alot from you since I discovered your videos! You're doing a bang up job at spreading alot of good ideas and letting us viewers have some fun!
    I do however wonder, is there a guide as how to build that KF airfoil? It looks like something I have to try to make!
    Again, thanks alot for hours of good entertainment and learning!
    This is one of the best episodes so far!
    LOL at the gremlin in the middle of the chart!
    RR5 Alien 5" - KISS FC · KISS 24A ESC · Lumenier 2206 2350kv · HQ 5x4x3 · HS1177 · Unify Pro · X4R-SB · Lumenier 1300mAh 4S 60C · Thunder Power Adrenaline 1300mAh 4S 80C
    Gremlin on the Wing Heli-Yeah!'s Avatar
    Lexington, KY USA
    240
    Turbulation? I don't know, Josh?
    This may have to go in the Flitetest made up word file.
    But seriously, great episode once again guys!
    I started a thread about KFm airfoils just last weekend. Ever since my first scratch build I have been consumed by thoughts of airfoils, foam, CF/FG rods, adhesives of all type. If only the power components where as cheap as it is to build a foam board aircraft.
    No wait........... Where would I sleep with foamies stacked to the ceiling?
    Sometimes magic sounds like tape........
    ~ The Amazing Johnathan
    YouTube channel MakerMike (a.k.a. Multi-Mike)
    Executive Producer StoneKap's Avatar
    Navarre, OH
    643
    Quote Originally Posted by Heli-Yeah! View Post
    Turbulation? I don't know Josh?
    Ha! Who's going to be the first one to start a "Words of Bixler" thread?
    Chad Kapper
    About to trademark: True Community Collaborated Entertainment!
    Let someone know that you believe in them... you'll be surprised at what they can do.
    Flying Derp bicyclemonkey's Avatar
    Fayetteville, AR
    1,887
    Quote Originally Posted by StoneKap View Post
    Who do you think?
    Starts with a c and ends with an x maybe?
    "Fly, yes. Land, no."
    -Henry Jones, Jr.
    alliedtechnwa.com
    Amateur Extra Class K5TWM
    3,103
    I love the KF airfoil, its easy to use and very adaptable to many different wing types. Recently I discovered a different type of foamboard wing over at RC Groups. The Armin Wing. Here is a link to a great tutorial of how to construct them:
    http://www.rcgroups.com/forums/showthread.php?t=1504758
    All people either serve the devil or God.
    To serve God you must follow his instructions
    because no man can think as God does.
    To serve the devil takes no effort or instruction
    ...just do anything you like.
    Who do you SERVE?
    Love the show, but I fear this was one with some technical hiccups... the diagram and the commentary trip a little and can get a little self contradictory in parts.
    the flat plate - the show starts off great with the flat plate, correctly identifying that it has no lift except with an attack angle, and that with the attack angle there's drag. The diagram says poor lift and no drag. Without incidence there's no lift, and when it's lifting there's lots of drag. Even without much/any incidence flat plates still have drag. Geeky detail is that at low reynolds numbers (very small planes or small slow planes), flat plates don't do all that bad compared to the other airfoils actually.
    Undercamber - identified as the most lift, and has a lot of drag. all good, although Josh B mentions that it's not a good airfoil to choose and the reason given is that it needs incidence to create lift. High lifting airfoils actually create lift at shallow negative attack angles, they certainly don't need an increased incidence to produce lift. Many high performance sailplanes use an undercamber to create lift without a positive attack angle which would ruin the efficiency by increasing drag.
    Flat bottoms - little more solid. To be splitting hairs, a Clark-Y airfoil isn't actually a true flat bottom wing, but it sure is close enough, that's cool by me... and the kids can learn the name of a genuine airfoil, gravy.
    Symmetrical - described in the diagram and on the show as creating lift when in fact it's the same class as the flat wing; creates zero lift until it's given an attack angle. The reason it's chosen for aerobatic planes is that it has the same characteristics upside down as the right way up, but in both attitudes provides no lift without an attack angle. You can get this without stick movement if you balance the plane the right way, but the wing itself cannot lift the plane unless it addresses the airflow with an attack angle. To further put the symmetrical and the flat plate in the same class, indoor aerobatic planes like those seen at the ETOC are flat plates or symmetrical sections. If you draw a line through the leading edge to the trailing edge and it's the same above the line as below, then it's symmetrical, and a flat plate being a really crude symmetrical section. Symmetrical is generally low drag (though there are many high drag symmetrical sections; control line pattern planes and RC "FunFly" planes as an example), but for a typical symmetrical wing it's dependent on "induced drag", or how heavy the plane is that sets the need for the attack angle which sets the amount of drag it has beyond its natural shape
    KFm airfoils - a fantastic compromise on a complex airfoil, sure are easy to build
    ...well, that's my spiel on the tech side of this episode. I'm really not down on the show, just that this was one episode about technical details and there were some issues with the info. The show is still awesome and truly fantastic, onwards and upwards!
    Site Moderator bmsweb's Avatar
    Australia
    791
    Never thought the KF airfoil would work so good! Nice work guys
