Results 1 to 8 of 8
    Member CrackerMcGillicuddy's Avatar
    Northwest PA
    48
    Champ Wing & Other WIngs
    My old Hobbyzone Champ has had a hard life, it was my trainer so it got bashed up good. I've changed it around a few times. First I changed it to a 1930's racer - the ChampRacer:
    Then I made it into the ChampUAV:
    Now it's the ChampWing:
    The hardest part of the project was getting the elevon linkages from the AR6400 brick to the elevon horns. This is the best I could do with that brick. I made 'cranks' out of carbon fiber but it still doesn't provide much elevon movement. It flies just good enough to stay airborne, that's it. The servos just aren't strong enough for all the extra levers and whatnot.
    Here's my other flying wings:
    Lots of RC aircraft, RC junkie!
    Rotor Riot! colorex's Avatar
    5,663
    I like the design of the UAV, is it a kit? I also like your last pic! It looks awesome!
    RR5 Alien 5" - KISS FC · KISS 24A ESC · Lumenier 2206 2350kv · HQ 5x4x3 · HS1177 · Unify Pro · X4R-SB · Lumenier 1300mAh 4S 60C · Thunder Power Adrenaline 1300mAh 4S 80C
    Northwest PA
    48
    No, it's just something I made out of depron foam. I wanted something small that fits in the Champ box that I could take on vacation and take aerial videos with. The Champ can hold a keychain camera no problem but the spinning prop in front ruins the video. The ChampUAV didn't handle very well - too bottom heavy (made it hard to tilt/turn) and with the keychain camera on top of the wing it handled even worse.
    Northwest PA
    48
    Oh, the wing isn't depron. The wing was from a toy-store styrofoam glider.
    Moderator earthsciteach's Avatar
    6,731
    Charles Darwin and Alfred Wallace would be proud. You should write a paper on "The Evolution of the Hobbyzone Champ."
    Old age member pgerts's Avatar
    Fjälkinge Scania Sweden
    1,552
    Quote Originally Posted by earthsciteach View Post
    DONT! Send it to http://www.darwinawards.com/darwin/
    Senior flyer - every gram counts!
    Crazy flyer/crasher :D ananas1301's Avatar
    Germany
    1,480
    Hahahahahahahaha pgerts!
    He truly should, would be so funny if gets a awards.
    Northwest PA
    48
    The Champ's AR6400 'brick' servos couldn't handle the stress of moving elevons. It died. I completely re-did the ChampWing and made it into the "UMX Wing". I used HobbyKing ParkJet parts - motor, ESC, servos and one of those little HobbyKing receivers (the tiny OrangeRX in shrinkwrap). Now it's much better. Here's a couple photos:
ID:	2472Click image for larger version.
