Page 1 of 48 1 2 3 11 ... LastLast
Results 1 to 10 of 476
    Hobbyking Buddy codes - Share your's here!
    It's good to get stuff even cheaper than HK prices!
    I'll get the ball rolling, feel free to post your buddy codes on this thread.
    Find my codes here: http://hk.rc-international.info/swarm/rcjim11 (valid until December 08, 2011)
    HXT500 5g / .8kg / .10sec Micro Servo Save US$: 0.44
    Jim
    http://www.youtube.com/user/Rcjim11
    The 'Most Fun Per Buck Club' rules state...............'the amount of fun you have is directly related to how much money you don't spend'.
    Rotor Riot! colorex's Avatar
    5,663
    Nice of you to create this post, unfortunately, my purchase was all buddy codes so nothing to share from me... If I get something on Buddy Code later on, I'll share it here.
    RR5 Alien 5" - KISS FC · KISS 24A ESC · Lumenier 2206 2350kv · HQ 5x4x3 · HS1177 · Unify Pro · X4R-SB · Lumenier 1300mAh 4S 60C · Thunder Power Adrenaline 1300mAh 4S 80C
    Awesome! Thanks Colorex
    Jim
    Full Circle teflyer's Avatar
    Texas
    402
    Here is mine.
    Valid until November 29
    Zippy 2S 350mAh 20C-
    http://www.hobbyking.com/buddy.asp?c...9-0B973F938E94
    Valid until December 2
    SF E Prop 7x5-http://www.hobbyking.com/buddy.asp?c...0-3C55CCFCD482
    2mm Gold Connectors 10 pairs-http://www.hobbyking.com/buddy.asp?c...A-9FDA1869481A
    Turnigy 2mm Heat Shrink Tube (Black)-http://www.hobbyking.com/buddy.asp?c...F-1C2057CA888B
    Hope this helps someone.
    Estonia
    9
    FMA Co-Pilot 2-Channel Flight Stabilization System CPD4
    Cheap and good semi-autopilot. Let go the sticks and plane/copter recovers to level flight in seconds. Good item and saves a plane or two for sure.
    Trying out new tricks, smoother camera flight, ideal for beginners, also helps when testing range or with fail-safe activating keeps the bird in level flight or make level turn in desired direction. Lots of usages!
    Buddy value
    Standard value
    Valid: 11.12.11
    2
    Here are some buddycodes from my christmasgiftshopping!
    Picked up a Tuff Trainer for my little brother to start out with, and figured I needed to treat myself with a Tek Sumo for being so nice to him!
    http://www.hobbyking.com/buddy.asp?c...4-9830B64672E8
    Turnigy L2210A-1650 Brushless Motor (180w)
    http://www.hobbyking.com/buddy.asp?c...2-52F9E92DFEE1
    Turnigy TY-P1 25Amp HEXFET® Brushless Speed
    http://www.hobbyking.com/buddy.asp?c...C-556C1A835267
    Turnigy Tek Sumo
    And here for some LED strips (time to build a nightflier since it gets dark here in Norway around 4pm)
    http://www.hobbyking.com/buddy.asp?c...4-48780B3EA4E5 Blue
    http://www.hobbyking.com/buddy.asp?c...E-73E0800B1A00 White
    http://www.hobbyking.com/buddy.asp?c...D-634C6871BBB7 Red
    http://www.hobbyking.com/buddy.asp?c...F-2885A468361D Green
    5,663
    OK, here is a buddy code:
    TGS Sport 6x4E Precision propeller
    Normal Price $0.51
    Buddy Price $0.48
    Not much, but something.
    Dec 2011
    MX2 Blue 3D 1400mm EPO (PNF) save 10$
    http://www.hobbyking.com/buddy.asp?c...2-A4A531A9C206
    Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V2 save 4$
    http://www.hobbyking.com/buddy.asp?c...9-5435A7DB422B
    Quanum 2.4Ghz Telemetry System Temp/Amp add-on save $5
    http://www.hobbyking.com/buddy.asp?c...F-79931E658260
    Turnigy Heat Shrink Tube 14mm BLACK (1mtr) save $0.50 per mtr
    http://www.hobbyking.com/buddy.asp?c...1-F3D200246A7C
    expires in a week, i didnt know about this untill today. pretty sweet
    make sure your signed into your hobbyking account for these to work
    Dec 2011
    Turnigy High Density R/C LED Flexible Strip-
    http://www.hobbyking.com/buddy.asp?c...2-CEE08840EFBA
    Turnigy nano-tech 370mah 3S 25~40C Lipo Pack
    http://www.hobbyking.com/buddy.asp?c...7-EEA86C51EB24
    JST Female 2 pin connector set (10pcs/set)
    http://www.hobbyking.com/buddy.asp?c...D-9259D5818FFE
    valid to 1011.12.17.
    Keep them coming!
    Jim
