3D Printed Motor Mount Pod
Part 3D Printed Motor Mount Pod 1
Please log in to download
Type
This is a motor mount & pod that I made for my highly modified FT Super Bee, because I wanted a stronger motor mount for my application, but it can be used anywhere similar motor mounts are found on FT planes.
If using on the FT Super Bee, you will need to cut two additional slots in the bottom of the wing for the motor mount tabs to fit into. Otherwise, use at your own discretion!
Motor mount holes are sized for EMAX RS2205, RS2306, and any similar sized motors with 16mm x 19mm hole spacing and M3 screw holes.
Here is my example application:
Author
Mid7night
Downloads
113
Views
1,716
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Mid7night
