EZ Intruder 15
Plane EZ Intruder 15 1.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
EZ Intruder 15
Design by: Dan Sponholz
The EZ Intruder design is inspired by the Air Hogs Intruder circa 2001. The Intruder was developed by Spin Master Toys, and sold under the Air Hogs and E Chargers brands back in 2001. Later in 2003 it was rebranded as the Resistor with 2 new liveries. The original toy had a 19 inch wingspan. My design began back in 2020 when the Flite Test EZ v1 electronics were out. The v1 electronics did not have enough power to provide a decent flight experience with a 19 inch wingspan, so I opted to reduce the wingspan to 15 inches. With the EZ v2 electronics the flight performance is incredible.
Specs:
Wingspan : 15 Inches
CG : 1.5 inches [38 mm] from the leading edge at the root chord.
EZ Configuration: Tractor
Right Motor: Blue : B Prop
Left Motor: RED : A Prop
*Note : To change your EZ v2 Power Pack configuration from pusher to tractor all you need to do is FLIP the props. Curved side faces the motor.​
Make sure to add the 2 pennies (or equivalent) nose weight to get the proper CG (see plans).
Skins: Stephen Rosema (Rasterize) did an amazing job on the original liveries for the Intruder and Resistor. Check them out here:
EZ Intruder and Resistor Skins
*Note : If you build from the skins you will need to increase the size of the cutouts for the v.2 motors. Everything else will build exactly the same as the plans.​
For more information about the Flite Test EZ series electronics and planes check out this Flite Test video:
Store Links:
FT STEM 2Ch EZ Power Pack v.2
Author
SP0NZ
Downloads
136
Views
5,821
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from SP0NZ
