EZ Raptor (Not FT)
Plane EZ Raptor (Not FT) v1.0
Please log in to download
Author
AIRFORGE
Downloads
206
Views
2,695
First release
Last update
Rating
5.00 star(s) 4 ratings
More resources from AIRFORGE
Latest reviews
I have built four of these and they fly great on two channel.I print them
them out using 3x3 preference on Microsoft printer . IT comes out bigger than original and some changes like slot for fuselage and motor
have to be adjusted and the slot at rear of fuselage. they all have to be made smaller but then to me it flies even better than the original which I have made and also flies great. The bigger one is a little slower and works better for my grand kids
Flies great and easy to build, thanks for sharing. Wanted to make sure it flew well before skinning (thanks @GrizWiz) so that is the next step because a very stable flyer overall for everyone. Even the 6 year old took a turn, though he should stick to 2ch for now, the plane was able to take some really hard hits with ease.
I did trim the gray ESC holder and glued it to the underneath so it has a "factory" trap door to close in the battery. Not sure what you did on the bottom but it is straightforward enough to experiment with.
AIRFORGE
AIRFORGE
Thank you, brother!
I make sure the width of the battery slot/pocket is narrower than the battery, and snug enough to grip and hold the batt in place. I experimented with hook/loop, tape, etc., but like the snug fit better.
The skin will add a bit of weight, so remove as much paper as you can before skinning. And, it will be easier to skin before assembly.
Thanks, again! Enjoy!
Great little plane!
All in weight came to 49g, and it flies well!
Thanks so much for this great design addicted!!!
AIRFORGE
AIRFORGE
Thank You!
And, especially, Thank You for all your help, and great SKINS, man!
