Fire Wall for Mr Mans MS Mini Corsair
Part Fire Wall for Mr Mans MS Mini Corsair Fire wall for Mr man's MS Mini Corsair V.1
Please log in to download
Type
Build Plan (PDF, AI, etc.)
This is meant for Mr Mans Mighty mini master series Corsair if you don't have a 3D printer. It is similar to the FT firewall for there Master Series Mighty Mini's.
Note: As the mount hole size of each motor is different you might have to adjust the hole distance slightly. Also as this doesn't have the thrust angle that is required for his Corsair you have to use a couple washers to add it.
Author
Downloads
23
Views
820
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Houndpup Rc
Latest updates
  1. 16mmx16mm mounting size
    Updated the mounting hole span to fit the Emax 2306 Eco II Motor and others. From 16mmx 23mm to...
