Type
Build Plan (PDF, AI, etc.)
FT Charlie
The Flite Test Charlie was designed to be a quick and easy to fly build, the slowest and least agile of the Triad series.
The FT Charlie is compatible with the FT Alpha and FT Bravo kits. Each airplanes’ wings are built to be removable from the fuselage, and can be swapped with any of the other Triad planes, giving the builder essentially 9 planes to choose from.
The Swapping Of Wings Takes Less Than A Minute And Is Supported By Rubber Bands!
There is no need to re-calibrate the center of gravity on the aircraft after swapping, the CG remains the same no matter what combination you configure. This is great for the flight line and swapping with others, making it an enjoyable experience for all.
We want you to have an amazing experience both in building and flying. This kit comes with everything you need to complete the FT Bravo Aircraft. Push-rods, control horns, firewalls and all other items needed to make this airframe electronics ready are included in the kit. If you choose to purchase our power pack F and battery, balance, flight performance and assembly will be quick and easy.
Power Pack Compatibility:
Flite Test Airplanes are all designed around the use of various "Power Packs" which include an inexpensive Motor, ESC, Servo, & accessory package to complete each aircraft! The compatible power pack is listed below.
Specifications:
Weight: 8.1 Oz (Fully assembled; without battery)
Wingspan: 24 Inches (736mm)
Center of Gravity: 14 Inches from the Nose
Control Surface Throws: 16 Degrees
Expo Suggestions: 30%
Kit Includes:
  • Laser-cut Foam Airframe
  • Firewall
  • Push Rods
  • Control Horns
  • BarBQ Skewers
  • Velcro
  • Throw Gauge
  • Rubber Bands
  • Zip Ties
  • Specification Sheet
Needed to Complete:
  • (1) Brushless Motor: 2204-2205 Size; 2400kV Minimum
  • (1+) Propellers: 6x4.5
  • (1) ESC: 20-30 Amp
  • (1+) Battery: 3S 11.1V LiPo 800mAh
  • (2) Servos: ~5 Gram Micro Servos
Author
flitetest
Downloads
4,531
Views
4,531
First release
Last update
Rating
5.00 star(s) 2 ratings
More resources from flitetest
