Type
Build Plan (PDF, AI, etc.)
FT Guinea Pig
Designed By: Peter Sripol
Plans By: Dan Sponholz
Description:
The Flite Test Guinea Pig is the perfect platform to carry out the craziest experiments in the air. While it can carry a hefty payload, which can be dropped out the rear hatch, it can also be set up to carry out extreme aerobatic maneuvers. Use differential thrust to perform amazing 3D maneuvers such as harriers and knife edge. Tone down your controls and the Guinea behaves like a predictable trainer plane and is the perfect first time twin engine plane.
Speed Build Kit:
FT Guinea Pig Speed Build Kit
Power Pack Compatibility:
Power Pack C Twin Radial Edition
Specs:
Weight:
2.2Lbs (Fully assembled; without battery)
Wingspan: 58 Inches (1473mm)
Center of Gravity: 2 Inches (50mm) from leading edge of wing (Recommended)
Control Surface Throws: 16 degrees
Expo Suggestions: 30%
Free Plans: Click the Download Button in the upper-right corner of this page
* These plans have been updated to the latest format. The design of the model has not changed. Only the format has changed to make it easier to print and build from the plans.
Printing Instructions
DIY Templates
Videos:
Author
flitetest
Downloads
5,049
Views
5,049
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from flitetest
