Howard DGA-6 aka Mr. Mulligan
Plane Howard DGA-6 aka Mr. Mulligan 2.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
My (@mayan) design for the FTFC20 Challenge converting the Howard DGA-6 balsa plans into a foam board design based on the building techniques that the FT team uses including some modified simplified version of the recently released master series techniques.
GENERAL SPECIFICATIONS
WINGSPAN: 1097.28 mm | 43.2 in
CG from wing leading edge: 30 mm | 1.18 in
DRY WEIGHT: 453 g | 15.97 oz
EXPO: 30 %
CHANNELS: 4 (THR | AIL | ELV | RUD)
TESTED SETUPS
SERVOS: 5g or 9g
ESC: 20A +
MOTOR: (1) B pack with 10x5 prop (2) C pack motor with 9x4.7 prop
BATTERIES: 1300 mAh 3S, 2200 mAh 3S
Follow the support URL and watch the thread for more updates about the design.
*DISCLAIMER*
This design is still not finalized. Things like covers might not line up 100% for clean connections but those will be fixed soon after I get a few more flights under my belt with this plane and start building and finalizing the plans for the official release.
Author
mayan
Downloads
205
Views
1,461
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from mayan
Latest updates
  1. Cleaning up!
    Quick update. I cleaned out the plans leaving only the pieces that are needed to build the...
  2. URGENT FIX
    FIXED ON PLANS: # Wing top/bottom wing cords have been adjusted based on problems that have been...
Latest reviews
Amazing plans quality! Cant wait to start it
mayan
mayan
Thanks for the positive feedback hope the build goes well. If you have any questions just ask. Eventually I’ll also add a build video so let me know if you get stuck or things need to be explained.
