- Type
- Build Plan (PDF, AI, etc.)
Simple build, great sport flier, great for a trainer.
30" wingspan
1806-2280 motor
850 3S
4 channel
thrust angle 2-3 degrees right, 5-6 degrees down
AUW 280g
Build thread/discussion/videos HERE
NOTE: In trying to make this nice & easy, the downloadable pdf is formatted to 10 sheets of 8-1/2x11". Make sure you're set to "no scaling" or "scale to 100%" and also "center the plot". Try only one of the sheets to start.
If there are issues and you can't print it right, let me know and I might need to set this up in large sheets to be tiled by your idiot printer.
This is just a preview of the work before I created the downloadable pdf:
30" wingspan
1806-2280 motor
850 3S
4 channel
AUW 280g
Please note this is not a speedbuild kit to cut-glue-fly. You'll want to make a couple decisions during the build process, and some prior build experience is assumed. I've built a fun plane and you can download and use the plans I made for my build. Use it as a template, a pattern or a suggestion to create your own awesome plane! |
