Rasterize skins for FT Simple Storch Afrika Korps
Skin Rasterize skins for FT Simple Storch Afrika Korps 2018-08-27
Please log in to download
Type
Skins & Decals (PDF, AI, SVN, etc.)
Rasterize skins for FT Simple Storch Afrika Korps Size 24X36
The Fieseler Fi 156 V 2 Storch (Stork) observation and command plane was destined to become one of the most famous and versatile aircraft of World War II. This German flew such passengers as Hermann Göring, Benito Mussolini... and Even Winston Churchill. The famed “Desert Fox” and leader of the German Afrika Korps, Field Marshal Erwin Rommel; and almost all other senior German commanders, clamored for the sturdy little observation and command plane for their own use. The Storch was also the last German aircraft to be down on the western front being shot down with Colt 45's by and American Piper Cub!
The skins model an aircraft used in North Africa to rescue downed German pilots. The aircraft can be build with or without the swastika on the tail.
Download the skin from the link in the upper right or help support my efforts while saving time and ink by purchasing the full sized printed skins (No tiling needed!) delivered right to your door! A set of printed full size plans are included!
Go to www.Fliteskins.com.
**Please read the Hints and Tips at the bottom before printing and building! These are not for recommended for beginners!**
You must be comfortable with the flite Test build method before attempting skinning a plane. It is highly encouraged and recommended you build and fly a version of the plane you want to skin before hand.
Hints and Tips
  • Printing - Please check your Print Dialog box and make sure that under "Page Size & Handling" that the "Actual size" button is checked and NOT the "Fit" button. If "Fit" was chosen it can result in smaller sized prints even when the correct paper size is selected. So far this one tip, if not done, has wasted more time and money than anything else!
  • Again this is not a beginner build! You must be comfortable with the flite Test build method.
  • It is advisable that you download the full plans and have them available for viewing before beginning your build. You will need them for reference as score lines are not on the skin kits.
  • The horizontal stab - Do not completely cut through the slots on the horizontal satbalizer that receive the tabs on the fuselage. It is unnecessary and will detract from the look.
  • The Wing - I opted to just remove all the paper and only use the skins. I think after the spar is in it will be more than sufficiently strong.
  • The fuselage - Peel off the paper from just one side of the foam.
  • When a piece has two sides covered with skins:
    1. Rough cut one side of the skins from the paper
    2. Take an appropriate sized section of foam and peal the paper from both sides
    3. Glue the rough cut part to the foam and let dry
    4. Now trim the foam to the skin (art)
    5. Trim the other side of the skin from the paper
    6. Carefully align and glue the second side skin to the foam
  • Sheeting - To keep the color between pieces the same I printed out everything on the same paper - 24lbs bond although 20lbs bond would work as well and save a little weight. For parts that require card stock, (if applicable) I just glue the printed paper skin to a black sheet of the same paper then cut the piece out.
  • Sharpie Touch Ups - Use an appropriate color Sharpie for touch ups and edges
  • You can also cover the skins with a clear shelf liner. (see pic above) Sp0nz did this on his Bloody Brit and Baron as well as on all the Blue Angle A4’s You can also see this on his Ber Harber F16 Thunderbird. Has yet to be tested on a might mini sized aircarft
Author
Rasterize
Downloads
227
Views
1,969
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from Rasterize
Latest reviews
EXCELLENT..
Rasterize
Rasterize
Thank you kecem!
