Servo mount for HITEC HS-81 (FT XL PLANES)
Part Servo mount for HITEC HS-81 (FT XL PLANES) 1.0
Please log in to download
Type
I wanted to be able to swap servos on my Flite Test Super Scout XL so I whipped these up. These are sized for the HITEC HS-81 servos only (If somebody wanted to provide dimensions of the Flite Test XL Power Pack servos I'd gladly make a mount file for those as well). Works well if you glue them to the subskin servo doublers so they sandwich between layers but can also be retrofitted with some foam trimming. I do not know if they will fit other commonly used servos like the Surpass Hobbies 17gr. Uses the included HITEC hardware. Depending on material used, you may need to open the screw holes.
Thingiverse link: https://www.thingiverse.com/thing:7181065
  • Like
Reactions: Houndpup Rc
Author
SEEBO
Downloads
3
Views
658
First release
Last update
Rating
0.00 star(s) 0 ratings
