Tench: I'm not sure what the AUW is. Never measured it because it was so light for the wing area I was never concerned with the loading. I was much more concerned with the CG because these birds usually have a very narrow margin for error.
If anyone has a cough, I have a lozenge or two for you.
That ruler is 48" for those interested in the size of things for this project.
I finished up the other engine nacelle. I added the screen mesh at the front after the folds were made. It turned out much better than the first but I'll live with it. I also got the fore and aft sections of the fuselage cut and joined. I gave some overage on the aft end and removed foam to make the paper overlap on the inside of the seam. Joined them with hot glue and peeled off the paper for the outside. It was then that I realized I needed to just print out all the lozenge I would need for the project. 6 sheets of each pattern for the wings alone... so 12 of those sheets above are for the wings. I may be able to get the fuselage top and sides with two sheets but it may be easier to just make one big print. One sheet of the other color for the bottom. Plus I'll need to do the nose.
I'm re-verifying that my plans are correct as I go. I'm still working off the templates from the prototype. Only minor things were changed, like tabs and score lines.
