1/32 scale spruce goose questions......
Fuselage is cave sized. Cooling needs moving air so hopefully the place where you put your ESC's has that. I recall it had 4 row radials so perhaps the cowlings are big enough to shove the ESC in with the motor. Or you could use door screen for cockpit glass.
Thinking about it, seperate battery pack for radio and servos. The ESC could start fighting when they cut off, bad juju.
My leaning is to put them in the cowlings, but I’m kinda worried about water damage. Is it the kind of thing where they can get splashed a tad and not short out or am I playing with fire (literally) here?
Haven’t got much done this week but definitely have been brainstorming some different ideas. Would really like to get the fuselage all stiffened up, as well as start on the tail surfaces……
The wing is gonna be big enough that the traditional fold over FT wing might not work great. Might have to consider building it more you would build a sheeted balsa wing. Ahhhhh decisions decisions
Got some more work done last night, all the formers are in the fuselage and it’s almost ready to sheet the bottom. I could go two ways with this….. either try the FT method or fiberglass the bottom of the plane. Any thoughts??? Either of these methods are such that once I’m started I’m basically committed
From experience: water and electronics is not much of a problem anymore. Worst case put reciever in a baggie. Cant do much protection for the ESC's but everyone is happy if you leave wet stuff in the sun for a day (at least here in Reno) servos tend to be water resistant or not. Typical failure mode: corrosion breaking circuit or bridging another. If stull looks like mold on the boards a good toothbrushing will often fix it. Not like todays equipment costs a months take home any more.
Might suggest building something that uses your wingspan to get experience building structure favoring foamboards. Mostly you will have a skin failure inwards crease that leads to wing fold up, but arrow shafts and fishing rod blanks are super neat spars and plain clear pine appropriate sizing works well. Don't need oak.
