Here's a little tip/trick on mounting a horizontal stabilizer or wing perpendicular to the fuselage. In this case I'm lining up the horizontal stab.
First, I picked a spot that would allow me to easily move a string from one side of the fuselage to the other without obstruction. In this case, it was the hardwood at the front of the wing saddle. I found the exact center side-to-side and put the pin in. A small loop was tied in the string, and then placed over the pin. I picked a spot on the horizontal stab (not the elevator) and used the string to measure from the pin to the spot.
While keeping my spot on the string marked I simply move the string to the other side and line up with the same spot on the horizontal stab. If the marked spot is the same then the stabilizer is perpendicular to the fuselage. If one side measures longer than the other you simply re-position the stab and measure again until the measurements are the same.
Note that this will really only work is you measure to the same point on each side, and if your center-point for the pin is actually on the center line of the plane. Oh, and the stab needs to have a mirror image left to right as well. In my case, it was darn near perfect right from the start. I still need to level the mounting base for the stab and will then re-check the measurements before gluing the stab in place permanently.
