My new wing strut hardware has arrived, so on with more wing work (while not working on a couple other planes...). This stuff is fairly expensive for what you get, but it should be money well spent in making this plane look that much better.
It's also time to take care of a problem with the original covering. It was trimmed right up to the edge of the wing which meant it could come loose in the hot sun. Wrapping around the edge gives that much more material to secure the covering, plus it hides the balsa completely where the wing meets the fuselage. Any small imperfections (and there are plenty) would leave small gaps where you could see the structure.
The top of the wings have pinking tape to simulate what was used for rib stitching on the original, a very nice detail. I used some of my left-over Cub Yellow for the purpose, wrapping a small amount around the edge of the wing. It's not perfect, but will certainly help hide the balsa.
A quick spray of paint and it quickly blends in with the original pinking tape. The paint isn't a perfect match to the original SolarTex, but it's close and helps give the plane a "weathered" and field-patched appearance.
The fuselage wing location also needs the extra covering added, that'll be done after I do some more wing work.
.......Aaaaaaaaand, back to the wing!
Another detail which I wanted to fix is the mounting location for the wing struts. They were installed farther out on the wing than they should be, meaning the struts are quite long. I'm going to move the mounting points in 2" which should give it a better look (to me, at least. Nobody else will notice the difference!). A pair of captured nuts are installed inside the wing. To add new nuts requires access inside the wing, so out comes the Xacto knife <GULP>! Unfortunately I need to add some new structure for the captured nuts, so the pieces are being glued in. Once done the covering can be heated up to glue it back down. I'll get a little creative later on to hide the surgery. Eventually I'd like to re-cover the entire plane so I'm not 100% worried about a few visible scars at this time.
