In the previous post I mentioned some concern on the fuselage formers at the rear of the plane. It looked really half-assed how the stringers were attached with big globs of brittle old glue (you can see how it was applied so heavily it was running down the formers!) so I decided to replace them. It's extra work, but this is the time to do it... It's hard to tell for sure, but it does appear some repair work was done towards the tail. There are marks where balsa was removed and replaced, and some of the formers are weirdly mis-sized now. So all 5 upper formers are removed!
Removing the formers leaves only the center stringer, which is in good shape. There is some clean-up needed of all the old glue which will leave me with a good, flat surface to install new formers.
Here's a perfect example of what I'm trying to fix. F10 has a big chunk missing from the right side when compared to the outline on the plans. I'm also not a big fan of how the stringers have very little contact area with the former, so I'll change that slightly. I'm not sure why, but only F10 and F12 formers are shown on the plans, so I had to use the removed pieces for the other 3 formers as templates and make changes from there.
This is my version of F10. All I really did is add some extra material to support the stringers. The lightly drawn lines on the new pattern are outlines of the original former. In theory, the new style should give more support with only a minuscule weight penalty. Heck, by removing a lot of old glue I may still come out ahead!
Original F12 and my re-design behind it. Again, you can see all the old glue that dripped down the former. Even with the extra material I'm adding, the entire former will be recessed far enough so it doesn't show up through the covering material. Only the formers will be in contact with it.
I wasn't sure what I was going to do for servos. The plane came with them, but they didn't work when I hooked them up to my servo tester. They're a good name, and I wouldn't expect ALL of them to be fried, so maybe it was just an error on my end...
It turns out that old servos like this were wired differently than they are today. The power wire was at one end with the ground in the center. Now the power is in the center, so by simply swapping two pins they all work! Unfortunately for me, I already took delivery on new replacement servos. While the temptation is to simply use the new ones, I'd like to re-use the original equipment when possible and save the new ones for another project.
