Turning the attention to the aileron servos I ran into a problem. The first picture shows how the ailerons are done on the Clipped Wing Cub, a method I like. The servo is mounted to a removable "hatch" which gives you easy access to the servo and a nice straight pushrod. I couldn't figure out why the builder of this plane did the servos like this.
So that's what I did on the first wing. A hole for the control arm was roughed out, mounting blocks were added to the servo hatch, and everything fit nice and neat.
...except I didn't take the wing struts into consideration.
On the Clipped Wing Cub the struts aren't in the way so that method works well. Here, I run into clearance issues and the pushrod can end up rubbing on the strut. It turns out the plans were designed around this problem, and if I only bothered to look at the details before changing things... The picture doesn't show the problem well because this pushrod has a bend in it, which makes it look like there is more clearance than there really is.
So back to how things were! I'll adjust the servo placement a little, but can re-use the original hardware now. A little structure needs to be made where the pushrod exits the wing, which will be quick & easy to do.
