Hey there everyone! It has been too long since I’ve been active on the forum. I wish I could say I’ve been busy with loads of happy and exciting activities that kept me away from RC but unfortunately the opposite is true. 2021 was lousy and I’m glad it is over. I’ve still got a few speedbumps ahead for the next month or two BUT I am planning for a better 2022 with much more time to pursue my hobbies.
The Sweat Pea project is NOT dead. I’m actually pretty close to wrapping up the main gear. Once those are installed and working that project will take off again.
While I work through the mains on the 17 I have also started a “small” foamy project to get some instant gratification and to join in the Flite Fest 2022 WWI Dawn Patrol event. OK… so it isn’t small and it hasn’t been instant, but it has been a nice distraction.
With that said here is a recap of the build so far:
I started with a set of free balsa plans I found online, scaled them up 150%, and printed them at my local FedEx Office store
As this will be a pretty large biplane I wanted the wings to be easily removable but still strong, so I am going with hot-wired cores and Carbon Fiber spars with matching FG sleeves. I got my cores for the upper wing cut using the scale undercambered airfoil.
The spars will handle the flight loads, but I wanted a quick and easy way to align and retain the panels. I ended up designing and printing these inserts that glue into each panel. They have a pair of holes, one for a centering dowel and the other for a magnet. Using a pair of these for each panel the connection is rock solid, and one of the designs has a nice channel to make wire runs easy. If there are any remaining concerns about the wing panels departing in flight I'm planning on functional guy wires, so those will also help hold the wings together.
Rough Ailerons were cut from balsa. Before covering she will also get balsa leading and trailing edges, with the trailing edges cut to give that characteristic scalloped look.
