As for your request for ideas/help making the fuselage clean and scale like I would recommend that you plan the EDF installation and ducting first. Once the ducting is designed to fit inside the fuselage outline I would plan from the outer skin back to the Ducting/EDF.
A near perfectly smooth FB fuselage could be obtained buy planking strips of FB over formers. The planking would have the exterior paper removed and the formers would have facets or flat surfaces instead of the smooth curves you might use on a wooden model.
The strips are curved, glued, and edge shaped to fit and when all fitted and glued the whole, (paperless), exterior is sanded, sealed, filled, re-sanded and either painted or glassed. If you wish you could remove all foam after glassing and fit duct supports, battery supports Etc and finish the build as a basically empty to keep the weight down.
I am sure others may have their suggestions and some will possibly more suited to what you are imagining.
Just my thoughts!
Have fun!
P.S. Don't forget the flaps!
