1:9 Scale B-17G - 'Sweet Pea'
wilmracer
I build things that fly (sometimes)
Looking good man! I would advise you to add some weights to the side former to help keep it flat. I've had my side profiles skew a little before if the surface is not fully flat. The glueing and taping can make things warp a little and at this size, it may be enough to be a pain to correct. Simple sammich bags with sand would be fine.
Oh yeah... I have been using weights but they weren't there for those pictures. Definitely want to avoid warping. I figure another evening or two of skinning and I'll be done with this side and ready to flip her over.
willsonman
Builder Extraordinare
Awesome. Yeah, It goes faster than you think. I usually approach skinning this way in a checkerboard pattern... see this post from 2014! While the maiden on this one did not go well, I still have it to be rebuilt at some point. It was quite resilient in the nose-in crash. This technique is quite strong... even in just foam. The balsa will add more strength and add the benefit of being able to be on display in the sun.
wilmracer
Latest pictures from the sheeting. First half is now foam sheeted (minus a few spots that need some cleanup. Formers are installed on the other side and most of the center crutch is removed. I've now laid down some of the CF strip that is basically the only stringer and I've started working on the ply plate where the tailwheel retract will mount. I need to get some internals planned and framed out before sheeting the other side. Current weight is just a hair over 18oz.
wilmracer
Thanks all! I've had a bit of insomnia lately that has "helped" me get a lot done the last few days. It is catching up with me today so I'm calling it an early night, but I did get some progress made on the tail wheel gear mount. This will allow the unit to be bolted in with 6-32 hex bolts so it will be easily removable for service. Still yet to do is to add a few small triangular supports to the mount plates, add two small tubes to run the pull/pull cables through that will prevent the lines from rubbing on the retract, and then to remove additional material on the lower half. With any luck this will be the only ply in the aft fuse (not including necessary ply parts for the control surfaces and servo mounts).
willsonman
I'm looking at this thinking that some additional reinforcement may be wise. A simple hardwood or CF square tube spar across the entire plate at the back right at the point where the mount sits. There is likely to be some bounce and I'd hate to see that ply buckle or crack over time.
wilmracer
Makes sense. I'll look at adding a little bracing on the forward side of the plate. The retract does have an oleo on it but the travel is only 1/2" or so the plate will likely still see a bit of impact.
I was about to say the same thing...
wilmracer
Thanks for the update! What's the benefit of sheeting in balsa before glassing? Would it work to just glass over the foam?
I debated covering this on this video but decided to talk about it on the next one. Fiberglass over foam would definitely work, but when those models sit out in the sun and get hot the foam starts to outgas a bit. This can cause the glass to delaminate from the foam and create bubbles in the surface. My P-40 already has a number of these small bubbles. The easy solution is to just keep the models in the shade or covered when they aren't flying. For a model this size that will present a big challenge. Sheeting in balsa prevents this from happening.
That makes sense! I love these build threads because I get to learn so much!
