Cg is right at the high spot or bend in the wing.Thank you. Also, I have a couple questions. Where is the CG located on the plane? Would simple dihedral have the same effect as polyhedral? Would I be able to put in polyhedral by cutting off a 4 or 5 inch piece of the the end of each wing tip, sanding a slight bevel to it, and reattaching it with hot glue?
Thanks again.
Dihedral has roughly the same effect but can fly very differently. That one is a little harder to quantify just how differently though...
You can absolutely add poly that way!
