Thanks. I looked on thingiverse, but couldn't find any 9 cylinder, or even 7 cylinder radial engines in 1/8th scale. I found one on another site... I will see if I can use it.
Otherwise I will do like I did for the PT-17 and cut them out of layers of DTFB.
I am beginning to think illusion might be the best answer. Maybe an airbrush shadow would work? However, I plan on just painting this prototype to KISS.
3D lab print released their PT-17 build videos and showed how their radial engine goes together. That should fit the bill just fine. Granted, the files are $20-$30, but you get awesome engines + a 3D printable stearman.
Can do better than the movie! That aircraft is N9651 known as The "City of Philadelphia". It currently resides at Fantasy of Flight in Polk City, Florida. Its notable appearance was in Indiana Jones and the Temple of Doom.
WWagner you are correct. Thanks for the complement.
CaptBill, I glued the rings together, then took a rasp and took the big edges off, then took a sanding block and sanded the rest down to what I wanted. they could both probably use a little more sanding before painting.
I remember seeing (and hearing) the Ford Trimotor flying over Las Vegas when I moved here in the 1970's. It was in use for many years by Grand Canyon Airlines for tours. You might be interested in some photo details. http://www.grandcanyonairlines.com/equipment/the-ford-tri-motor/gallery
I'll be following your build with great interest!
Jon
Jon
Yes, I believe it is now housed at the Planes of Fame museum in Valle, just south of the Grand Canyon. At some point I may drive over and take a closer look at it.
