Trying to find a 10 gram brushless motor around 2000kv that will run 3 S, so far have not had much luck finding any,anybody have any links or motors numbers they have used in the past and had good luck with..
Wanting it for a Mini Stingray for indoor combat I can go with up to a 17 gram motor but recommended is a 10 gram here is a link to the plane. Hobbyking did have one but not available anymore.
Yes it is what I am looking for thing is when doing searches I end up getting side tracked after you came up with this one I finally did find one at HobbyKing for $7.74 in the US warehouse, but only includes the prop saver and I hate those. I will have to see if I have a collet style prop mount for it as the shaft is 2MM.
Thanks ended up ordering 2 of each, some 3.7 gram servos, and 5030 props be interesting how powerful these motors actually are. I am trying to keep the over all build under 100 grams for best performance..
