After having parts for my 100" PBY cut out by Todd and Keven at Flite Fest on their CNC machines, I had to build one of my own. Having parts cut out by machine is way, way nicer than by hand.
After some talking with Todd about his machine (an Openbuilds Ox), and what he might think about upgrading, I started searching around for a machine that would cut foam, but could also handle aluminum or even very light steel work, and had a wider working area.
After some browsing on google and the openbuilds.com forums, I came across the SMW3D R7.
https://sites.google.com/site/smw3dr7/home
It's 1000x1000, uses the stronger C-Beam aluminum extrusions, uses standard openbuilds parts, is ACME driven, and can carry an 800watt water cooled spindle.
Parts for my machine should arrive this Thursday, and in preparation I've been building a table for it to go on. Saw a flip table on the web, and decided to build my own version using 2x4's, 2x6's, a couple sheets of 3/4" MDF and a piece of 1.5x.120 tubing to use for the swivel point. Being able to flip the table and gain a nice flat working area will save a ton of space.
Drew things up in Sketchup first:
Then grabbed up supplies from Home Depot and started building.
I changed things a little bit from my original design to stiffen things up, but overall it's pretty close. Here's a link to the Sketchup file for the table for anybody that's interested.
https://drive.google.com/open?id=0ByQNh9_cWpIsblBad0lLVk5XQ2s
Only thing left to do on the table is install power outlets. I'm going to have a couple of switched outlets so I can shut things down manually if I need to, and several standard outlets on both sides of the table for whatever I might need. This table will serve as a workbench as well, so I'll at least need a spot to plug in my glue gun.
