120% FT Commuter Plans
I just got done testing out my 120% FT commuter plans. They worked out great. I have been working to get this plane to work with a B pack motor. This gives a 36" wingspan. I just finished up a 135% this morning which will be a 40" span. Both should work with B pack motor, but the 135% will fit a 1300 battery and 9g servos better.
Attached a DXF of the 120%. Its set up to cut with a .8mm bit
The plans for the 120% work great. I won't be powering this one though. Did some glide tests and it works well. The battery area was just not large enough for a 1300 battery. The 132% fuselage was built last night. I am making adjustments to it today to fit a 1300 battery, as it was so close.
I am not doing a bottom hatch on the 132% yet. I will need to see where the battery needs to sit for proper CG, and then i can see what needs to happen. There may be room for a 2200 battery even.
Will need to beef up the landing gear area as well
#4
Nice - I am building a 140% at the moment, looking at 1500 for the motor. Be interesting to see how it flies when done. The mini was good, so my guess is this should be better. I see you've backed off the dihedral. Same, I'm going to build the wing flat with a balsa spar. Considering full length alierons for flaperons.
The Hangar
Fly harder!
Lol - I flew my stock commuter on an a pack with two 9 gram servos and a 1500 2s battery! I’ll be eager to see how the up-scales versions fly.
#11
Yeah, I'll be pretty interested myself! This is built for a 3s 1500 powering a Tomcat P4002 940kv and a 10 in prop. Feels pretty strong...but I know stuff all about how all the volts etc work.
#13
Thank you so much. I'm assuming you are not going with the power pod. What do you have planned?
How much dihedral?
Thank you again.
No worries. I'm actually going with flat - 0% but I've seen people build them with just a little and others quite a bit. I'm going to start a thread now just for the build as it's been an interesting hybrid of foamboard and balsa construction.
#16
just an fyi the 140% plans above are missing the power pod and the part that the power pod slides into. Also i would cut the angle you cut in the top part wings (that allow the fold over parts to match up) a little bit less, it was quite a large gap and i didnt compensate for that part with blown up plans. now i gotta figure out some landing gear for it im thinking tail dragger but not sure yet. was gonna do it the way you did steverayK but got ahead of myself and already glued the front on lol.
Yes, sorry - I did not use a power pod, the internals including landing gear, were balsa initially. When that failed, I instead formed a solid styrofoam section inside the nose and just stuck the motor to that (use a firewall). I left the front part last as it is easier to work on all the internals before closing up the front section. One issue I did have was to be aware that the front section does not handle hard landings well, particular with a bit of motor weight - I had a few times where the nose sections pulled apart on landing. The strength to weight for the front is much better with the mini than upscaled. My landing gear worked really well though, it handled everything I threw at it - which was a lot!
