I still have a lot to think about. I definitely want to try other types of foam and other materials, but I would like to try to come up with a more scientific approach to test effectiveness of the laser than me pointing it at things. Like I mentioned earlier, I want to see how much current it is drawing as well as make some type of fixture to hold the laser steady and precisely relative to whatever I'm testing on. I've been pretty busy recently but now I have some free time to mess around with it.
I'm still very interested in seeing it progress. Even if it can't cut DTFB it's still a very useful tool. And you can always continue to experiment to see if you can find a way to cut DTFB.
I would also like to price out a 20-40W CO2 laser system and try to integrate support for that into my design as well, just in case somebody would rather spend a little extra on a CO2 system. For now I'm sticking with diodes though. I might try a few different Wavelength diodes. I think that may be the main limiting factor rather than power or focus. Since the foam is relatively translucent to the laser beam at this wavelength, the beam disperses and it won't cut. At least that's how it seems to me. That is why a CO2 laser works with this foam if I'm not mistaken.
If anybody has experience with lasery things I would appreciate any insight you may have on the matter.
I don't think wavelength is going to make a big difference. It would if this was a colored surface, in that case yeah, a different wavelength can make a big difference. But here, it's white. I think the issue is more that the structure of the foam is one that diffuses to effectively. All wavelengths are probably being diffused.
The CO2 laser works because it's MUCH higher power. And even then I hear it's tricky to get DTFB to cut well. (note how on FT's kits how much foam is missing around the cuts.) CO2 lasers also tend to make their power in the UV range so it's a much bigger change in wavelength - but makes things like focusing much trickier since you're no longer dealing with a visible beam.
I wouldn't be surprised if you could find some kind of combination of power, lens, wavelength and speed/passes that can cut DTFB...but the number of possible combos scares me from digging in trying
I would probably first get the laser mounted up to make testing more repeatable, then look into upgrading the optics and power supply on it to get better control/feedback
