I know the title says $150.
But for anyone who is looking for something not so DIY from a design standpoint...here are some videos of the Open Builds OX CNC system from Open Builds (
www.openbuilds.com)
About a year ago I calculated a BOM for an OX-CNC table using 1500mm x 1000mm Open Build V-Slot extrusion.
The damage was about $900, without the router or dremel.
Here's a video of Crash Hancock's OX CNC build.
Crash is a fellow Flitetest member, and originator of the Crash Cast Podcast.
https://www.youtube.com/watch?v=akobisDZzqA.
Here's another OX CNC with the guy cutting out a bloody wonder.
https://www.youtube.com/watch?v=EONrHCKZ8kg
https://www.youtube.com/watch?v=FI5vtiPmYUc
I suspect a lot of you are drooling at this point...
If a suitable laser could be found, one that didn't require some elaborate mirror system, but could be mounted directly to the z-axis...this table would provide a nice mechanical base.
But my thinking is that you will require a pretty powerful lazer in order to have something remotely usable.
A lot of hackerspaces have lazers that have complex mirror systems, with the laser power starting at around 40 watts. Introducing mirrors into the equation really takes DIY off the table.
Besides the issue of mirrors, a 40W tube is pretty expensive consumable, as it has an expected life of only so many hours. I would imagine the Lazers used at FliteTest are using 60 to 80 watt tubes...and the replacement cost for one of these runs into the multiple hundreds of dollars.
That's why I think rotary cutting tools, rather than a lasers, would provide a much more suitable solution across multiple materials...Dollar Tree Foam Board, Depron, Pink or Blue foam board, bulsa, basswood, plywood, Plexiglass, Lexan, G10...etc.
A lot of guys forget that when using a laser you need to consider enclosing it in a airtight box with an active ventilation the outside using an air blower (compressor?).
A CNC laser in the basement, without an airtight enclosure and a powered ventilation system, is probably a non-starter.
On the other hand, you can run a rotary tool in your basement without much worry about chemical fumes.
You do have to worry about dust, but shop vacs and dust shoes can do a decent job of addressing this issue.
If you're still interested, here is a 2-part video on the OX CNC table build:
https://www.youtube.com/watch?v=nS32b55ouQk
https://www.youtube.com/watch?v=8JufQ-xCvdg
