18mm Rotary Cutter
Hoomi
I picked this up today at Hobby Lobby (currently 50% off, so a whopping $3.50). When the bevel on the handle is placed flat against 3/8" foamboard, the blade will cut almost all the way through, just shy of the paper on the other side. Replacement blades are normally $4.99 for a 2 pack, but are also 50% off right now.
I believe Olfa and Fiskars also make small rotary cutters in this size range, but I haven't checked those to see how they compare on the molding or depth of cut. I'll be putting this one to the test when I start making the new wing for the Sensei.
LoidLiu
I use the one by Fiskars cutter. That's easy to use, and everything is fine at all. It is not too big, and good to hold in hand.
