micro_builder
Got this thing pretty much finished and test flown, thrust line needs a bit of tweaking, but otherwise seems good to go, will get a proper flight video up soon. My lightest so far, by nearly a full gram...the 10mah lipos really drop the weight. Considering adding the elevator, but I'd want it full flying like the rudder, but I'm not sure if the actuator will be strong enough for so much area...would up the weight too, but would probably be pretty fun.
5.25x3" wing
2.1g flying weight
4x8mm motor with watch gear gearbox and balsa prop
remote magnetic actuator for rudder
DasMikro MiRX32M 3 channel RX
10mah lipo
0.25 - 0.75mm Carbon fiber wings, tail and fuselage stick
Ultrafilm wing covering
5.25x3" wing
2.1g flying weight
10mah lipo
