Question is: Does it need to sink to be considered
I keep pushing my mind around this LPL Flying Sub. I love the look of it. like a flying Manta Ray
I also keep thinking about this plane's design challenges. If I build it I'll want to make it easy to build yet sinkable.
The Numbers... How feasible *is* this... (thank you all for the notes about sinking systems, and the note about signal loss.)
I'm going to use metric here as volume/weight/displacement is VERY easy in metric.
Displacement: 534g
Each foam board displaces 36g of water. My initial design is 4 sheets. (a c-size will take 8 at least)
I will assume the entire plane floods except the cockpit area I would have a watertight container in there.
The size is roughly 6.5x12x5cm or 390 ccm so that means the plane must weigh 534g. (1.2 lbs) for a 3 (4) engine Plane.
Weight: 355 - 560(ish)
5 -9g servos - 45g
4 - 40g motor setups (2205 with 30a ESCs and 5" prop, producing around 1.8kg thrust (for 3 engines)) 120g
8 channel receiver or FC - 10g
4S 1500 - 3500maH battery - 188 - 385g
So I see this as a matter of playing with the WT capsule size VS. Battery or foam load-out. to get things to balance when the plane floods.
Wing loading is 19oz./1.57sf or 12oz.sf That's between glider and a trainer. Add two torpedoes, and now we're talking!
I put an A-size Plan set together.
I plan on building/testing it this week. *should've* cut it out last night. I realized soldering connectors on, and getting the Kalinin K-12 ready for a weekend test is time better spent (for now).
I have reached out to *the* Bob Martin IE
www.RC-SUB.com and on Youtube he's RCSubGuy. This guy has a true passion and talent for submarines. He estimates a larger amount than I have to build this as a submerging vessel. (while I'm still trying to see what I can do to mitigate the Costs.) His sites, encouragement knowledge and thorough videos, should help me know how we can manage this. While a bit discouraged by the cost, I think I could set limitations of the vessel and get away with a less costly setup... but I'm not sure.
I think I can get a flying/floating model with plans and article/vid by year end. Just not sure about getting to Full-Montey completed by then.
Question is: If I add this craft, to the List of Projects - does it need to Sink to be considered?
