2025 High speed Challenge
End date
  • August 17th
    Votes: 4 66.7%
  • September 22th
    Votes: 2 33.3%
  • Total voters
    6
  • Poll closed .
Rumors of +180, but just gps displays, no good repeating videos of the actual through traps. Dunno, the guy could own a porsche or Countache. Glider guys do it more than once, videoed
L Edge
Actually, unless you see an entire video of the flight, you don't know how it was obtained since most GPS readings only record top speeds, so was it in a dive? straight and level? etc, What's the accuracy of the GPS?
At least fly it across the field in a race track pattern at a 50-100(no wind) ft height so we can see it to believe it or dive down in front of the camera.. The G's pulled in a turn or pullup will tell the story of the structure of foam. Fluttering can become a problem as mentioned by Mr. P. So, seeing is believing.
Yeah, I barely go into a dive that way I barely have to pull out. They Radjet doesn't have any CF spars..
I am using a drone GPS that has a 10hz refresh rate so it's accurate!
I said dives are okay because the goal is to say what the materials can hold up too! (Especially foam board....)
Do we have a running list of who is at what speed whith what aircraft? Been busy with FliteFest stuff and haven't kept up with all the threads.
I am at 0. I have only flown one 15" quad due to weather and time constraints.
Now we do! (I edited this post at the bottom I will have each of us in order of speed..)
