Looked up data for ABS and found that in vibration and bending, it is moderate to good. For torsion, rated poor to moderate. Wow, so it looks like you should pay attention to the way you make the part and may be add a safety factor or two.
First case to mind I envisioned is the fuse, high torque from prop, gusty winds from wings, tail feathers, gear,etc acting on your many printed layers could snap the least bonded.
You live in a warm climate, how about the planes below freezing, where the inter layers bonds turn brittle which could snap under vibration or shock.
Most of the time for the average flyer, no problems, but going for speed, when you have high rpm's, these are only some of the factors that need to evaluate when you make that turn pulling many G"s.
This is what got my attention about ABS, heating beyond its printing zone or resting against a hot nozzle can start thermal composition. This releases volatile organic compounds and ultra-fine particles, necessitating proper ventilation or an air filtration system.
That's scary, if one inhales any of that crap.
