2026 Speed Challenge - MadMonkey
L Edge
Looks very sleek. My experience with the Eclipson designs has been that they tend to tune the aerodynamics to have good slow flight characteristics, frequently at the expense of top end speed - I can't tell from the picture, but I'm guessing the wing uses a fairly nice flying but somewhat draggy airfoil, at least based on the planes I've flown from them
You can bet that it was designed to look sleek(for sales), but it will be slow. The nose is way to fat(holding battery?) and by positioning the cockpit way aft , the turbulent airflow will cause interference with the tail in a sharp, sharp turn causing failure.
Ask me how I know about flutter.
MadMonkey
I dunno what your definition of slow is... I'm not looking to set a record with it, but I'll definitely be able to hit at least 130-140 with it with the power system I have in mind 😉
Well, as long as my prints don't turn into confetti in flight.
MadMonkey
Eliminator work is back on! Motors have arrived. I had to print new mounts because I forgot the new motors are 16x16 though 🫩
Then I had to stop in a panic because I thought I ran out of CF tubes and rods... fortunately I found a bag of about 8 new ones so I'm good there.
Spars and other CF parts are cut and assembly starts soon!
MadMonkey
Slowly but surely
MadMonkey
I can't find my linkages... one of the perils of moving 🫩
More on the way from Amazon. Due to the high speeds I'm running short pushrods with ball links on both ends for minimal play. I still wince every time I hit top speed on 3D printed planes due to expecting a "pbBbBbBbB CRACK" sound (that's flutter).
Motors are mounted and assembly is almost complete. I wish black painted parts would hold up better in central Texas, I had a good idea for a color scheme... guess I'll do something different.
MadMonkey
I think the speed of development and material performance is a massive plus.
Balsa? Way too long to design, build, test, redesign, etc. Even foam core fiberglassed planes would take a lot longer.
Foamboard, while a hoot for building in general, isn't going to hold up the best at high speed.
3D printing has been a huge boon to the hobby! I haven't done a full plane design but I've done a lot of parts and mods. Eventually I'll do the whole shebang... there's a few cool designs out there I want to try.
RickHunter
I have built a few 3d printed planes before, but this will be my first speed 3d printed plane. This is my concern as well. It's already printed and put together. I was thinking of going back over any glue points with some thin super glue for added strength. Any advice?
MadMonkey
I'm fairly new to it as well, I've only done around 6 planes or so. I don't think more CA on the joints could hurt anything...
I've been wondering if fiberglassing some particularly stressed areas would be worthwhile.
RickHunter
I didn't think of fiberglassing it. I think I'll try more CA first. If I experience R.U.D. then redo it with some fiberglass.
telnar1236
Never a bad idea to go back over seams with an extra bead of CA and then wipe away the excess. In general, I think 3D printed planes are stronger than they need to be especially when not using LW-PLA - the only time I've ever had any issues with flutter I was flying pretty slow and it was completely my fault for a terrible control linkage design. I did fiberglass one of my early 3D printed designs and my experience there was that it added a fair bit of weight for not very much improvement - the plane held together fine both before and after, and the couple of crashes after weren't any less damaging
telnar1236
if you are able to print in ABS it helps a ton - I live in Florida and I've pretty much given up on using PLA for anything other than one-off designs that I don't intend to keep for very long or fly very often. Had too many situations where a single darker colored line somewhere on a plane would ruin a whole part after a couple minutes in the sun but with ABS I've built a couple all black or dark gray designs and they couldn't care less if you leave them in a hot car all day or in full sun for hours.
MadMonkey
Servos and motors are mounted. I had to modify the servo covers since my linkages are a little large.
Annoyingly, I can't find my canopy magnets, so that's another thing I'll have to order unless I can dig through my boxes and find them. I was hoping for a maiden this weekend but it's looking like next weekend instead, and possibly my speed runs if all goes well.
I gotta paint too!
telnar1236
I gotta paint too!
Looking good! At the speeds this thing will be flying might be worth taping the canopy on too for a bit of extra security
MadMonkey
She'd be ready for paint except I've run into two more issues... the Radiomaster receiver I have is gaaaarrrbaaaaaage and won't hold link even in the same room. That, and the new battery I got for the speed runs has a bad connector. I don't like soldering battery connectors so I'm gonna return it and get a new one.
Also one of the elevons was EXTREMELY tight ( this happens every time) so I sat in front of the TV flopping it back and forth for a while until it loosened up. Should be okay now.
I dunno if you've built one of these, but while that recommendation would spot on on any other plane, the canopy on these have full-length rails AND magnets. It's the one thing I don't worry about, they're actually a pain to get on and off until you've worn them in 😂
RickHunter
Yes. I had to sand both the canopy and the other hatch on mine just to get them to slide on easier. I put the magnets on her, but don't know if even they were needed. Got my esc's in today, so just waiting on a parallel connector to come in Tuesday and hopefully take her out Wednesday or Sunday for a maiden. Running an ER6 with GPS as a receiver for the first time, with the GPS on the inside for aerodynamics. Hope it doesn't get blocked.
MadMonkey
After further troubleshooting it's not my receiver and battery... it's my brand new out of the box BEC 🫪 I was annoyed after all the problems, so coincidences made me make an assumption... I had just read about problems with the receivers, and the UBEC was going into thermal shutdown right when I would wiggle the battery connections.
Good advice for everyone... calm down and think!
I do tend to have bad luck though. When I was about to leave the office on Friday one of my technicians returned a USB cable he'd borrowed. I plugged it into my workbench and tossed the end down. Fortunately I was watching, because it slapped my solder station power switch and turned it on 😵‍💫
Anyway... new BEC I guess. Sheesh.
Oh, I also had the receiver on the wrong protocol. It still bound, but the link was trash. Again my fault lol.
