2026 Speed Challenge - MadMonkey
I’m still on the fence on whether or not I should pull the fc out of my drone and put it into this next plane, considering it’ll have about 4.5HP…
If you decide to, maybe try it in something like an arrow or goblin first to get used to tuning...
telnar1236
Actually it seems this same chap raised the record to 247.6mph...3 days ago!😂😂
I do somewhat question the 246 mph number. A 90mm EDF on 8s is a stupidly powerful setup and should be able to push a plane that size to that speed, but the designer only recorded I want to say 152 mph or so on that plane with a very similar setup, which makes me question how the plane gained almost 100 mph. One possibility is that it was just flown better and more aggressively for the 246 mph runs, especially if it had some help from a tail wind and considering that it was a slicker ABS airframe instead of an LW-PLA design. Another is the GPS ended up too close to some electronics or had the sampling rate set too high and ended up with an incorrect speed. Either way, it's still stupidly fast
All of which goes to say, the record might still be waiting to be set - would be curious to see what doppler readings would say
telnar1236
I can't believe you're brave enough to fly it so low and close 😂😂
3D printed planes change the game with high-speed handling. I've been consistently impressed by how little they change their flight characteristics instead of getting twitchy or weird like some foam designs
That is interesting..It's still cooking when he does those runs!😂
MadMonkey
This will be my official (probably final) entry as I don't think I can break this unless I have a good tailwind. This thing was COOKING!!
203.18mph
I'm thrilled with this. Somebody beat me!!
