telnar1236
Got the entire nose fuselage and most of wing as well as part of the core fuselage of the Mk 2 Super Duper Sabre printed out.
As well as the changes to the aerodynamics, I'm also switching back to normal ABS. The new infill patterns get about the same level of warping with normal ABS as the gyroid infill did with CF ABS so I'm comfortable with the precision I can achieve now. And normal ABS, as well as being much tougher and less prone to cracking which should hopefully help the plane survive a bit better, is much less of a pain to post process since it doesn't produce carbon fiber dust when you sand it. It's also half the price which is good given how many parts I've needed to reprint. And I can print it in "silver" (more like slightly metallic gray) which puts a thunderbirds livery back on the table.
Along with the other changes, I'm also increasing the height of the tail to compensate for the increased wind and stabilator area. With how much it's changed, I'm debating going back to the original name of the Wraith since it no longer resembles an F-100 anywhere near as closely.
