I'm just getting back into RC after 15 years away. I just completed building a TF Mini Tiny Trainer for 3 channels. This was my first-time using foam and hot glue. The plane went together easily. Final weight of the foam structure was 184 grams. Final flying weight with electronics and 900 mah battery came to 302 grams.
Since I had to wait for my new transmitter (arrives today), I built two additional planes: one using Elmer's foam and one using Readi board. I also constrained my build to one 30 x 20 sheet per plane, necessitating a 30" wingspan down from 36". I followed the same technics as used in building the FT trainer.
The Elmer's plane came out to 341 grams, the Readi plane came out to 231 grams. In all three planes the servos used are the heavier 9gms vice 5gms.
The Readi plane is way under the 250 gram FAA stupid limit and the Elmer's is way over, as expected. Looking back at my building experience I believe I could build a 250 gram TF trainer by using 5gm servos and cutting way back on the glue (I know I used way too much) and dropping the battery to a 400 -.600 mah.
I liked working with the Elmer's foam. It is a lot more solid and easier to work with. I believe the Elmer's plane will take a lot more abuse, and with a little more power fly better in windy conditions. The Readi board is really cheap, more "flimsy", and has ripples in the surface. I don't view it as very crash resistant. The proof will be in how they fly, of course. I expect to let you know by the end of the week. I would appreciate your comments about your own experience building and flying such small and light planes.
