white crown
Hello! I am looking to try to get into the hobby again after seeing all this as3x and safe tech being incorporated into planes. First I will tell you my sad one-flight story from my first attempt.
Several years ago, after thorough research and recommendations from the local hobby shop, I bought an Eflite Apprentice RTF kit. It was supposed to be the absolute BEST beginner kit on the market. I spent a week tinkering and verifying everything, test taxiing, practicing control stick movement, etc. while I was waiting for a calm day. I have a lot of simulator (not RC) experience and was fairly confident, so I decided to do my first flight on a windy but not gusty day... Grass field takeoff was successful and uneventful with a little right rudder and slight aileron after V1. I climbed up to altitude and initiated a left roll with slight rudder to coordinate a turn into the crosswind leg, while adding throttle to about 2/3rds to maintain altitude through the turn. As the plane came across the wind it immediately shot towards the ground like it was being sucked down by a super-magnet. As a beginner not having built any reflexes on this control platform, I had zero time to react. As the plane struck the ground nose-first the motor mount broke, ripping the motor through the bottom of the cowl and the forces splitting the mid-fuselage in half.
I repaired the motor mount with pieces of bamboo skewer and CA glue and hot glued the fuselage back together. At the time I couldn't figure out what happened, as far as I knew that would have been a textbook turn on the simulator. Also at this time, I was reading about potentially having to register with the FAA to continue to fly this plane. Since I still had a working aircraft, and not wanting to finish completely destroying my $350 or go through a registration hassle to do so, I cut my losses and sold it on craigslist for $250.
Looking back I think the left wing stalled when turning, as the wind from the right side was being interrupted by the fuselage. That coupled with my current control set-up; left aileron, left rudder, and advanced throttle, created a ground seeking rocket. Had I removed throttle immediately I may have had time to realize and correct flight control surfaces.
I'm just reading about this new stabilization tech, and with the <250 gram registration exemption, and I think safe mode on a micro could give me the training wheels I need, not having the availability of an actual instructor. Right now I am looking to buy a little Champ without ailerons to get myself into trouble and not heavy enough to disintegrate itself (also cheap to destroy, not $350). If that goes well I will move up to a 4 channel UMX with Safe, having the Champ as a backup for potential crashes/failures and second plane for my daughter who is old enough now to try this herself... once I figure it out enough to teach her.
I'm excited to try this again. Any suggestions or advice is welcome, most of all thanks for reading my long first post!
